I have big problems configuring application access for the SAPgui application (other applications are working fine). For me it seems that - once the hostname of a SAP server is resolved - the server's IP address is contacted directly. I have two questions :
a) (for WebVPN experts) Is it possible to access directly the server's real IP address using WebVPN ? In case this is not possible with the current version, is it likely that this will work with some later software release ?
b) (for SAP application specialists) Is it possible somehow to configure the client or the server to use only the hostname instead of the IP address ?
Thank you very much in advance !
