Inbound traffic problems...
e3consulting
Well, it all seems pretty straight forward. I must be missing something, but I cannot for the life of me see it. Traffic is flowing out just fine, but no OWA or Remote Desktop Web Connection (does this use port 3389??). Exchange mail does flow in and out just fine!
Here is my config, is there a problem?
prompt(config)# show conf
: Saved
: Written by enable_15 at 04:51:04.796 UTC Fri Sep 23 2005
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password
passwd
hostname xxxxxxxx
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
no fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list email permit tcp any host x.x.x.x eq smtp
access-list email permit tcp any host x.x.x.x eq www
access-list email permit icmp any any echo-reply
access-list email permit icmp any any time-exceeded
access-list email permit icmp any any unreachable
access-list email permit tcp any host x.x.x.x eq https
pager lines 21
logging monitor debugging
logging buffered debugging
mtu outside 1500
mtu inside 1500
ip address outside x.x.x.x x.x.x.x
ip address inside 10.0.0.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 interface
static (inside,outside) tcp interface smtp 10.0.0.11 smtp netmask 255.255.255.25
5 0 0
static (inside,outside) tcp interface https 10.0.0.11 https netmask 255.255.255.
255 0 0
static (inside,outside) tcp interface www 10.0.0.8 www netmask 255.255.255.255 0
access-group email in interface outside
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 1:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 25
dhcpd address 10.0.0.30-10.0.0.100 inside
dhcpd dns 10.0.0.8
dhcpd wins 10.0.0.8
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd enable inside
terminal width 80
prompt(config)#
16 Replies 16
subaa
You wrote: 'but no OWA or Remote Desktop Web Connection (does this use port 3389??).'
Where from or where to?
If from the outside to 10.0.0.11 or .8, then you should change the access-list email and let it out. Also modify the static for 3389.
If it does not work from the othe internal host to the outside, it is more simple> there is no network address translation configured.
Add this:
nat (inside) 1 10.0.0.0 255.255.255.0
global (outside) 1 int outside
Bests,
Attila Suba
This is for the outside Internet into my network.
The Exchange server is IP .11 and the Remote Desktop Web Connection (Terminal Services Web) is on .8.
It still is not working... Easy to get working? Well, not if you want any traffic to be allowed in.
I'm at the end of my ropes here folks...
From what I know (which is admittedly very little), my access lists should be all that I need. port 80 needs to be routed to the exchange server for Outlook web access (along with https).
I currently have a Sonicwall POS that allows the proper traffic in and out, but is very inadaqueate for how the company has grown...
just wondering if you have done "sh xlate | in 10.0.0.11" to verify the static statements.
also try to do "clear xlate" every time you modified the nat/global/static.
I've done the clear xlate (and do it every time I make changes). Also I ran the show xlate to verify them and they looked good.
Thanks for your reply. I think I'm going back to zero and rebuilding the thing from scratch again.
do "telnet 3389" from a pc located from the internet or outside the pix. then do "sh access-l" on the pix to see whether the acl has been hitted or not.
if yes, then there maybe sth wrong with the server. try the same command "telnet 3389" from a lan pc to verify.
Thanks for the suggestion. I will try these things shortly and report back!
Thanks!
Mike
just wondering how you go.
Thank you for your interest. I haven't been able to test it yet, as the company is in the middle of some large projects... Plan is to work on it tonight. I really appreciate your help on this!
Mike
I am working on it and am not having much luck. Did a 'clear xlate' as recommended. I cannot connect using 'telnet 3389' and am not getting a hit count using 'show access-l'
I am able to connect using telnet .
Same goes for 80, 25. Exchange IS sending and receiving email through the PIX though.
Also, the server CANNOT be misconfigured because the Sonicwall works perfectly on all necessary tasks (tsweb, OWA, etc).
What the heck am I doing wrong??????
"I cannot connect using 'telnet 3389' and am not getting a hit count using 'show access-l'"
that means the pix has not received any rdp request. just wondering if you were testing outside the pix such as from the internet.
also please post the latest part of static and acl email.
At this moment I am testing inside the firewall. Is that a problem? I should be able to hit OWA using the public IP from inside my network, right?
Static:
static (inside,outside) tcp interface smtp 10.0.0.11 smtp netmask 255.255.255.255 0 0
static (inside,outside) tcp interface https 10.0.0.11 https netmask 255.255.255.255 0 0
static (inside,outside) tcp interface www 10.0.0.11 www netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 3389 10.0.0.8 3389 netmask 255.255.255.255 0 0
show access-l
alert-interval 300
access-list email; 7 elements
access-list email line 1 permit tcp any host x.x.x.x eq smtp (hitcnt=138)
access-list email line 2 permit tcp any host x.x.x.x eq www (hitcnt=34)
access-list email line 3 permit icmp any any echo-reply (hitcnt=4)
access-list email line 4 permit icmp any any time-exceeded (hitcnt=0)
access-list email line 5 permit icmp any any unreachable (hitcnt=6)
access-list email line 6 permit tcp any host x.x.x.x eq https (hitcnt=0)
access-list email line 7 permit tcp any host x.x.x.x eq 3389 (hitcnt=0)
no, the public ip is mapped on the pix outside interface. you need to test it from outside world, such as from home or you can use a dial-up connection.
Ouch, I was afraid of that! Well, I'll see what I can come up with since going home is out of the question! I'll try dial up now. Thanks!
