Inbound traffic problems...
e3consulting
Well, it all seems pretty straight forward. I must be missing something, but I cannot for the life of me see it. Traffic is flowing out just fine, but no OWA or Remote Desktop Web Connection (does this use port 3389??). Exchange mail does flow in and out just fine!
Here is my config, is there a problem?
prompt(config)# show conf
: Saved
: Written by enable_15 at 04:51:04.796 UTC Fri Sep 23 2005
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password
passwd
hostname xxxxxxxx
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
no fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list email permit tcp any host x.x.x.x eq smtp
access-list email permit tcp any host x.x.x.x eq www
access-list email permit icmp any any echo-reply
access-list email permit icmp any any time-exceeded
access-list email permit icmp any any unreachable
access-list email permit tcp any host x.x.x.x eq https
pager lines 21
logging monitor debugging
logging buffered debugging
mtu outside 1500
mtu inside 1500
ip address outside x.x.x.x x.x.x.x
ip address inside 10.0.0.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 interface
static (inside,outside) tcp interface smtp 10.0.0.11 smtp netmask 255.255.255.25
5 0 0
static (inside,outside) tcp interface https 10.0.0.11 https netmask 255.255.255.
255 0 0
static (inside,outside) tcp interface www 10.0.0.8 www netmask 255.255.255.255 0
access-group email in interface outside
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 1:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 25
dhcpd address 10.0.0.30-10.0.0.100 inside
dhcpd dns 10.0.0.8
dhcpd wins 10.0.0.8
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd enable inside
terminal width 80
prompt(config)#
16 Replies 16
Well, that was it. Everything is working perfect. Thank you for the patience and help you have given a complete Pix rookie. All this time, I configured it correctly but just did not test it properly. Committed the cardinal sin, I assumed based on experience with the Sonicwall device.
Again, Thank you!
Mike
it's good to learn that your issue has been resolved.
according to cisco:
Why should I rate posts?
If you see a post that you think deserves recognition, please take a moment to rate it.
You'll be helping yourself and others to quickly identify useful content -- as determined by members. And you'll be ensuring that people who generously share their expertise are properly acknowledged. As posts are rated, the value of those ratings are accumulated as "points" and summarized on the Member Profile page and on each member's Preferences page.
