12-17-2003 08:15 AM - edited 03-09-2019 05:55 AM
On my 4X sensor, I keep on getting an indeterminant state on the Secuirty Monitor's Connections tab. I have full connectivity to the sensor on port 22 and 443. I am able to ssh both ways, and I am able to use the IDM tool via 443. What I havent seen is alarms being forwarded back to the MC. Im sure this is why its in an indeterminate state, but if I can use the IDM tool and 443 is open, why wouldnt it work properly? Im kind of stumped on this one.
12-17-2003 09:01 AM
This state indicates that the connection status record has not yet been written for this device in the database. It will only show up in two situations.
The device is added while the system is very busy and the user checks the connection status before the receiver is able to create the collector thread for the device.
The device was added while the receiver process was stopped.
Try rebooting the VMS server and if this doesn't work,deleting and adding back the IDS
thanks
yatin
12-17-2003 09:47 AM
OK, I figured out the problem....but this kind of leads me to ask another question.
The dbserv7 process was hung at 20%. This probably occupied the system to an extent where it wasn't able to create the collector thread.
This is far from the first issue I have had with dbserv7. It always seems to get hung around 20% especially after reports are run or the EvsServer is run. To correct the problem (75% of the time this works) I have been first stopping dmgtd, then deleting the .SQLAnywhere directory out of the /tmp directory. After waiting about 5 minutes I restart dmgtd. Smetimes this works, sometimes it doesnt. Whenever you interrupt a process, i.e.closing the EvsServer window before it displays alarms or Canceling out a hung report, the dbserv7 process goes to 20% and stays there. Anyone have any information on this process or their own experiences in dealing with this?
12-17-2003 03:20 PM
In Security Monitor. Go to "Administration" "Process Management" choose "stop process" and stop only the IDS_Receiver process. Once it has been stopped. Start it again and it should show connected.
12-18-2003 04:14 AM
That would not work because dbsrv7 was hung. THe only thing that worked was what I mentioned above.
