IOS IPSEC - Manual ISAKMP
tckoon
I configured IPSEC VPN between 2 sites with ISAKMP turn off. Currently it works, but the problem is only the access-list sequence number one is bind to the IPSEC
, subsequent number of the access-list 121 does not appear on IPSEC, when I perform show crypto ipsec sa. Why ? Normally if using dynamic ISAKMP, we can see all the source and destination defind on te access-list. ??
When perform the ping test I can only ping from 192.168.7.0 network to 172.17.1.0 hosts, not other.
If I remove the first sequence , then from 192.168.8.0 can ping to 172.17.1.0 hosts.
Eg.
access-list 121 permit ip 192.168.7.0 0.0.0.255 172.17.1.0 0.0.0.255
access-list 121 permit ip 192.168.8.0 0.0.0.255 172.17.1.0 0.0.0.255
access-list 121 permit ip 193.168.1.0 0.0.0.255 172.17.1.0 0.0.0.255
Harold Ritter
This is a restriction of using ipsec-manual. You can only specify one line in the ACL the subsequent lines are ignored.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Thanks for the answer.
Another question is if I have same router/interface/crypto map. Is it possible I build IPSEC to one site with Manual ISAKMP and another site with auto ISAKMP ?
If possible how and can you provide the config.
Many Thanks.
Many Thanks.
yes, you can. you can one long crypto map with different sequence numbers and you can use which method you want for each part of this crypto map. For example;
crypto map test 10 ipsec-manual
set peer ...
match adddres ...
crypto map test 20 ipsec-isakmp
set peer ...
match adddres ...
for manual ipsec a sample configuration;
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080093c26.shtml
hope this helps..
