01-09-2009 01:11 PM
Hi all,
If I install the Snare for Windows on my server that has already installed the MS Exchange I will be able to receive the Exchange logs?
Solved! Go to Solution.
01-12-2009 05:28 AM
You can with the Epilog product by intersect alliance. Its similar to SNARE, buts its for different kinds of logs. It will do exchange message tracking logs, SMTP logs, IIS, squid and others, as well as basic text files. I use it to do IIS logging.
01-12-2009 05:28 AM
01-14-2009 10:25 AM
Tks so much patwill66, you help so much!!!
regars,
Rodrigo Alves
