ISAKMP Phase 1 getting stuck at ISAKMP: callback: no SA found for 0.0.0.0/0
mbadali
I'm trying to connect an IPSec tunnel to an external site based on the following document.
http://www.cisco.com/en/US/customer/tech/tk583/tk372/technologies_configuration_example09186a0080143b0a.shtml
I've set this up successfully in the lab with four routers (2 hubs and 2 sites) and am now trying to set up the connection to an external site. When Phase 1 negotiation starts ISAKMP states the following errors (no SA found for 0.0.0.0/0.0.0.0 [vrf 0]). The only thing different between the lab and prod configs are the external addresses(private(lab) vs public (production)). Obviously the new prod config is using a publicy routeable address in fa 2/0. I'm wondering if the router recongizes that and is trying to use VRF. I was intending on doing this without VRF. The ISAKMP negotiation stops immediately after the router states that ISAKMP is ON.
To wake up the process I remove and readd the crypto map to the interface.
r12(config)#int fa 2/0
r12(config-if)#no cry
r12(config-if)#no crypto m
r12(config-if)#no crypto map B2B
r12(config-if)#
*Jul 28 09:54:22.848: ISAKMP: callback: no SA found for 0.0.0.0/0.0.0.0 [vrf 0]
*Jul 28 09:54:22.848: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
r12(config-if)#crypto map B2B
r12(config-if)#
*Jul 28 09:54:31.036: ISAKMP: callback: no SA found for 0.0.0.0/0.0.0.0 [vrf 0]
*Jul 28 09:54:31.036: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
The following debugging was turned on for the above messages:
r12#sho debugging
Cryptographic Subsystem:
Crypto ISAKMP debugging is on
Crypto Engine debugging is on
Crypto Routing debugging is on
Crypto IPSEC debugging is on
Any suggestions would be helpful. Thank you
Pertinant Config (7206 with an SA-VAM):
crypto isakmp policy 4
authentication pre-share
crypto isakmp key xxxxxx address x.y.z.a
crypto isakmp key xxxxxx address x.y.z.b
crypto isakmp invalid-spi-recovery
crypto ipsec transform-set encrypt-traffic-des esp-des esp-md5-hmac
crypto ipsec transform-set encrypt-traffic-3des esp-3des esp-md5-hmac
crypto map B2B local-address FastEthernet2/0
crypto map B2B 20 ipsec-isakmp
set peer x.y.z.a
set transform-set encrypt-traffic-des
match address site1
crypto map B2B 30 ipsec-isakmp
set peer x.y.z.b
match address test
interface FastEthernet2/0
description Internet Facing Interface
ip address 2.2.2.2 255.255.255.192
crypto map B2B
umedryk
Level 5
Level 5
This looks like a time out error. Did you change any timer on PIX from default value ?
