Kazaa traffic needs explaining
chrisv
Below is a sample of KaZaA alarms detected by my IDS that is on
the inside of our firewall. My IDS on the outside of the firewall
is not detecting the traffic. That makes sense, since udp 1214 is
blocked at the firewall. The KaZaA user is 132.170.x.y. This user
is transmitting udp traffic to port 1214 to the IP addressed listed
below as “Source.” This I am certain, I have sniffed this traffic.
132.170.x.y received these IP addresses through the initial hello
on port 80 from some “server.”
My question now is, is their something else happening here that
I am not aware of, or is “Source” and “Destination” on this signature
have been reversed?
Chris
Alarm Name: KaZaA v2 UDP Client Probe
Source Dest Details Sensor source port destination. port
12.217.88.31 132.170.x.y KazaA CSBIDS-1 1168 1214
12.247.147.37 132.170.x.y KazaA CSBIDS-1 1168 1214
12.250.218.29 132.170.x.y KazaA CSBIDS-1 1168 1214
12.253.113.184 132.170.x.y KazaA CSBIDS-1 1168 1214
18.242.0.158 132.170.x.y KazaA CSBIDS-1 1168 1214
24.52.199.23 132.170.x.y KazaA CSBIDS-1 1168 1214
24.65.42.160 132.170.x.y KazaA CSBIDS-1 1168 1214
24.73.9.160 132.170.x.y KazaA CSBIDS-1 1168 1214
24.79.125.38 132.170.x.y KazaA CSBIDS-1 1168 1214
24.81.71.137 132.170.x.y KazaA CSBIDS-1 1168 1214
24.130.16.39 132.170.x.y KazaA CSBIDS-1 1168 1214
24.131.112.98 132.170.x.y KazaA CSBIDS-1 1168 1214
24.147.177.71 132.170.x.y KazaA CSBIDS-1 1168 1214
24.153.53.229 132.170.x.y KazaA CSBIDS-1 1168 1214
24.158.73.56 132.170.x.y KazaA CSBIDS-1 1168 1214
mcerha
Level 3
Level 3
This is very strange. The signature is pretty specific, looking for "KaZaA" in the body of a UDP packet destined for for port 1214. Are you sure that you are sorting the data in the correct columns (source vs. dest) from the log files? If you'd like, I'd be happy to look at any log files or traffic samples that you can provide. You can send them to mcerha@cisco.com.
