LAN-2-LAN, with inside NAT
glen.stewart
Hi All,
I have a LAN-2-LAN VPN connection back to HO from a remote site. This router also has some NAT's defined to allow access to RDP from the internet etc.
Is there a way to also allow RDP using the internal address of the server once the NAT is in place?? Currently I can only access the server using RDP via its public address.
thanks in advance
ip nat inside source static tcp 172.28.9.1 3389 interface Dialer0 3389
thanks
kaachary
Hi Glen,
That would work, and for this you have to use PBR ( Policy Based Routing). Assuming the remote end subnet is 192.168.1.0/24 .
Here are the steps you need to follow :
1: Create an access-list to identify the traffic :
access-list 101 permit ip host 172.28.9.1 192.168.1.0 0.0.0.255
2: Create a loopback interface :
int loopback 1
ip address 1.1.1.1 255.255.255.0
exit
3: Create a route-map for PBR :
route-map pol_nat permit 10
match ip address 101
set ip next-hop 1.1.1.2
exit
4: Apply the route map to the LAN interface :
int fasteth0/0
ip policy route-map pol_nat
exit
That should do it !!
*Please rate if helped.
-Kanishka
kaachary
Hi Glen,
int loopback 1
exit
exit
int fasteth0/0
exit
-Kanishka
Thanks very much Kanishka, much appreciated.
