NACL3OOB question
srue
Level 7
Level 7
When a Windows user log out of their PC (which has already been posture assessed and placed into the appropriate access VLAN) but doesn't shut down or reboot, is there any way to notify the CAM of this and 'move' the switchport back to the auth VLAN so if a different user logs in they must be posture assessed under their own username/account?
TIA
bmg
Level 4
Level 4
I have not found any way to go around this either, Cisco told me to use the "clean-up agent" on the CAM, but this is not a good solution because i got my PC's located behind IP phones, and therefor i can't bounce the port, and changing VLAN on a computer that is on is causing ip address problems. Hope Cisco works this out, or anyone else has any great ideas.
