NAT on 2621 HELP!!!
segillett
I have spent a few hours trying to NAT out a few intenal 192.168.x.x hosts through both my ethernet1/0 interface and also tryed using another IP from the range. Any help GREATLY appreciated. Thanks! (Config below)
Building configuration...
Current configuration : 1021 bytes
version 12.3
service password-encryption
hostname 2621
boot-start-marker
boot-end-marker
enable secret xxxx
enable password xxxx
no aaa new-model
ip subnet-zero
ip name-server xx.xx.xx.xx
ip audit po max-events 100
interface FastEthernet0/0
ip address 65.126.x.x.x.255.252
duplex auto
speed auto
interface FastEthernet0/1
ip nat inside
speed auto
half-duplex
interface Ethernet1/0
ip address 65.126.x.x.x.255.240
ip nat outside
half-duplex
ip nat inside source list 7 interface Ethernet1/0 overload
no ip http server
no ip http secure-server
ip classless
no ip route static inter-vrf
ip route 0.0.0.0 0.0.x.x.x.121.117
line con 0
line aux 0
line vty 0 4
password xxx
login
end
5 Replies 5
Josef Oduwo
Level 7
Level 7
At first glance I think you may have to check or define access list 7 (see this line ip nat inside source list 7 interface Ethernet1/0 overload) that will state what traffic can proceed to e1/0.
Otherwise exactly what do you want NAT to do?
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080093fca.shtml has a very good piece on how NAT uses ACls and http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080100548.shtml covers commonly used IP ACLs.
Cheers,
Josef.
thanks joe, since I posted i caught that and have this in there
access-list 7 permit 192.168.1.0 0.0.0.250
it still does not. I am really at a loss here sitting in the datacenter at 9;30pm. Do I need to route the 192.x.x.x somewhere (tried all options), thanks for any more advice.
7 years old post but i have the CCNA Composite exam in 36 hours so i'll ignore that and answer.
I'm assuming a basic setup (like the one in the question) with PAT and many-to-one source translation.
The steps to properly configure NAT are:
1) list all your interfaces and track which ones are your *internal* interfaces and which one is your *external* one. In the configuration given by OP, the "inside" interface is Fastethernet 0/1. The "outside" interface is Ethernet 1/0.
2) Declare the interfaces one by one, this is done in the interface configuration dialog with the statement "ip nat inside" and "ip nat outside" for the respective interfaces.
3) Gather your traffic, with an ACL. This step is necessary to teach the router which traffic he should consider for Network Address Translation. It is achieved by an acl that permits traffic coming from the subnets configured on our "inside" interfaces. In this case, 192.168.1.0/24.
The reason OP can't get NAT to work is because his ACL was at first absent, and subsequently mistyped.
It should be
ip access-list standard 7
permit 192.168.1.0 0.0.0.255
deny any
The deny statement is implied but explicitly adding it simplifies troubleshooting as every packet matching it will show up in
# show access-lists
ACLs use a "wildcard" mask notation for defining  groups of addresses. For all intents and purposes at this level, they  are just another format  for the subnet masks but they can be used in  other ways.
You obtain your wildcard mask by subtracting the  subnet mask bits (in decimal) from 255.255.255.255. In this case:  255.255.255.255 - 255.255.255.0 (the subnet mask for a /24 network) =  0.0.0.255. Therefore, the mistake lies in the ACL statement.
4) Activate NAT with the general configuration dialog statement "ip nat inside source list LISTNAME interface INTERFACEID overload
5) Troubleshoot if needed by using show access-lists, show ip nat translations, debug ip nat . It only works when you see relevant data in the output of those commands.
You do *not* have to route anything, as that would defy the entire purpose of NAT.
If i made any mistake in my post please point it out. I think i got my head around NAT pretty ok but you never know.
Any feedback is welcome.
G.
p.juarezponte
I think Giulio's answer is quite good.
I'd only add one thing,
I would change
for this other line:
ip route 0.0.0.0 0.0.0.0 Ethernet1/0
The router will not have to make another search and it should be faster.
You can view if NAT is the problem using
You should see if nat is working fine.
Can you ping the next hop interface eth1/0?
Is your Eth1/0 up up?
If you can't ping the other interface, make sure your ip address of your ETH1/0 have an ip adress between 65.126.121.112/28 and 65.126.121.127/28 (except the next hop 65.126.121.117).
and eth1/0 should be up up, of course.
I hope this helps
