02-16-2004 10:52 AM - edited 03-09-2019 06:26 AM
I need to implement the NAT outside command:
I configure it in this way:
static (outside,inside) 10.1.1.1 192.168.1.1 255.255...
where 10.1.1.1 is the address translated inside of the ousider address 192.168.1.1, so it is able to initiate a communication towards other 10.1.1.x
but it doesn't seems to function
and if I do a show xlate I don't see this entry.
where is the error?
NB: I use a Pix515 running 6.2(2)
02-17-2004 01:49 AM
Please read the following document and see if this helps your situation:
http://www.cisco.com/warp/public/707/28.html
Regards - Jay
02-17-2004 03:58 AM
already read: I have done like this document explain but it doesn't function.
when I run the show xlate command, there isn't the corrispondent entry
Thanks for any suggestion!
Lorenzo
02-17-2004 04:28 AM
Hi Lorenzo,
Can you maybe post your config please (remember to exclude real IPs and password) and also can you provide any syslog messages from the PIX. If you like you can post direct to me - jmia@ohgroup.co.uk
Also, did you issue command clear xlate after the changes on the config? And saved with command write mem
Thanks - Jay
