NAT outside
I need to implement the NAT outside command:
I configure it in this way:
nat (outside,inside) 10.1.1.1 192.168.1.1 255.255...
where 10.1.1.1 is the address translated inside of the ousider address 192.168.1.1, so it is able to initiate a communication towards other 10.1.1.x
but it doesn't seems to function
and if I do a show xlate I don't see this entry.
where is the error?
NB: I use a Pix515 running 6.2(2)
nkhawaja
there is no such command as
the command should be
static (outside,inside) 10.1.1.1 192.168.1.1 255.255...
but it is supported in PIX6.3 code.
right: static and not nat, but it is a writing error.
and for this doc
http://www.cisco.com/warp/public/707/28.html#topic12
it is supported from 6.2 ...
is there any syslog message being generated?
what is the output of "show xlat local
Nadeem
