11-18-2018 09:54 AM - edited 03-10-2019 01:07 AM
Dear Cisco Experts,
We have a bit unusual task - need to allow RDP access from PC outside one ASA to PC outside another ASA via inside network. See attached drawing.
For the moment I'm able to establish RDP sessions to/from test machine as shown by green arrows:
a) RDP client from 192.168.117.211 to server 172.16.8.21 by connecting as 192.168.117.1:50001
b) RDP client from 172.16.8.21 to server 10.3.117.211 by connecting as 172.16.8.201:12119
Configuration of both firewalls below
==== TA-FWL ==== ! interface GigabitEthernet1/1 description WiMax nameif outside security-level 0 ip address 10.3.117.1 255.255.255.0 ! interface GigabitEthernet1/2 description PCN nameif inside security-level 100 ip address 172.16.8.201 255.255.248.0 ! object network PC-211-3389 host 10.3.117.211 nat (outside,inside) static interface service tcp 3389 12119 route inside 195.0.0.0 255.255.255.0 172.16.8.231 1 ==== SA-FWL ==== ! interface GigabitEthernet1/1 description WiMax nameif outside security-level 0 ip address 192.168.117.1 255.255.255.0 ! interface GigabitEthernet1/2 description PCN nameif inside security-level 100 ip address 195.0.0.201 255.255.255.0 ! object network PC-211-3389 host 192.168.117.211 nat (outside,inside) static interface service tcp 3389 12119 object network TEST-RDP host 172.16.8.21 nat (inside,outside) static interface service tcp 3389 50001 access-list OUTSIDE-IN extended permit tcp any object TEST-RDP access-group OUTSIDE-IN in interface outside route inside 172.16.8.0 255.255.248.0 195.0.0.231 5
However when I change
to
object network TEST-RDP host 172.16.8.201 nat (inside,outside) static interface service tcp 12119 50001
RDP session could not be established.
Anything else I've missed form ASA's configuration?
Thank you in advance,
Yuri
Solved! Go to Solution.
11-25-2018 08:01 PM
Hi Yuri,
If I understood you correctly, I think this configuration should work for what you need, assuming you don't have an access-list on inside of TA-FWL. If you do, adjust it to allow the connection. In summary, this configuration should allow host 192.168.117.211 to initiate a connection to 192.168.117.1:50002 ( I changed the port, see comment in config). At the SA-FWL, the destination address:port will be NAT'ed to 10.3.117.211:3389 and routed towards TA-FWL. TA-FWL will NAT the source IP of 192.168.117.211 to 10.3.117.1 while keeping the port intact, i.e.3389.
==== SA-FWL ====
description WiMax
nameif outside
security-level 0
description PCN
nameif inside
security-level 100
object network RDP-CLIENT
object network RDP-SERVER
host 10.3.117.211
nat (inside,outside) static interface service tcp 3389 50002
! Here you'll need to use a different port, since 50001 is already mapped to 172.16.8.21:3389
route inside 10.3.117.0 255.255.255.0 195.0.0.231 1
access-list OUTSIDE-IN extended permit tcp object RDP-CLIENT object RDP-SERVER eq 50002
==== TA-FWL ====
description WiMax
nameif outside
security-level 0
description PCN
nameif inside
security-level 100
nat (inside,outside) static interface service tcp 3389 3389
route inside 192.168.117.0 255.255.255.0 172.16.8.231 1
Regards.
Cezar
11-19-2018 01:06 AM
Topic moved to "Firewalls" category.
11-24-2018 09:10 PM
Yuri,
When configuring a static NAT in the form '(outside,inside) static interface' you're translating the source IP of your outside host to the IP address of the firewall inside interface. If you want to translate it again on the other firewall, you'll need to have something like this:
object network TEST-RDP host 195.0.0.201 #on TA-FWL or host 172.16.8.201 on SA-FWL nat (inside,outside) static interface service tcp 'port' 'mapped-port'
Now the ports. Since, after first translation, your destination port is already 3389, you don't need to translate it and you can try 'service tcp 3389 3389'
Hope that helps.
11-24-2018 09:13 PM
11-25-2018 03:45 AM
Hi Cezar,
Unfortunately we could not avoid NAT. My drawing was simplified - actually we have 50+ special devices behind TA-FWL on 10.3.117.0 network which must be accessed from main server 172.16.8.111 via single inside IP of firewall. So we used NAT port convention: 1__ip__service, i.e.
inside address 172.16.0.201:12223 mapped to outside 10.3.117.222 port 503
inside address 172.16.0.201:12238 mapped to outside 10.3.117.223 port 80
And sorry I did not understand your advice in the first reply. I will explain what I need exactly. Current firewalls configuration allows me:
Launch RDP client on 192.168.117.211 with connection to 192.168.117.1:50001 --> connected to RDP server on 172.16.8.21 port 3389
Launch RDP client on 172.16.8.21 with connection to 172.16.8.201:12119 --> connected to RDP server on 10.3.117.211 port 3389
Now I need to:
Launch RDP client on 192.168.117.211 with connection to 192.168.117.1:50001 --> connected to RDP server on 10.3.117.211 port 3389
Please advise,
Yuri
11-25-2018 08:01 PM
Hi Yuri,
==== SA-FWL ====
description WiMax
nameif outside
security-level 0
description PCN
nameif inside
security-level 100
host 10.3.117.211
==== TA-FWL ====
description WiMax
nameif outside
security-level 0
description PCN
nameif inside
security-level 100
Regards.
Cezar
11-26-2018 06:49 AM
Hi Cezar,
Thanks for pointing me in right direction, I got it working now!
The problem was with missing routes to "outside" networks on both firewalls.
Cheers,
Yuri
