04-27-2005 06:22 AM - edited 03-09-2019 11:04 AM
I am still trying to have this PAT translation and NAT issue resolved.
Here is what I have done:
|------------> DMZ1 (security90)
| (172.16.28.0 255.255.255.0)
INSIDE (security100)----
(172.16.0.0 255.255.248.0)|
|------------> DMZ2 (security85)
(172.16.32.0 255.255.248.0)
access-list dmz-2-inside permit ip 172.16.28.0 255.255.255.0 172.16.0.0 255.255.248.0
static (inside,dmz) 172.16.28.0 access-list dmz-2-inside
access-list outside-2-inside permit ip 172.16.32.0 255.255.248.0 172.16.0.0 255.255.248.0
static (inside,dmz2) 172.16.32.0 access-list outside-2-inside
nat (inside) 1 access-list nonat-inside-dmz 0 0
nat (inside) 2 access-list nonat-inside-outside 0 0
nat (dmz) 0 172.16.28.0 255.255.255.0 outside 0 0
nat (dmz2) 0 172.16.32.0 255.255.248.0 outside 0 0
global (dmz) 1 interface
global (dmz2) 2 interface
access-list nonat-inside-dmz line 1 permit ip 172.16.0.0 255.255.248.0 172.16.28.0 255.255.255.0
access-list nonat-inside-outside line 1 permit ip 172.16.0.0 255.255.248.0 172.16.32.0 255.255.248.0
I need to accomplish the following:
-traffic sourced from the 172.16.0.0/21 destined to the 172.16.28.0/24 needs to be PAT to the IP
address of the DMZ1 interface.
-traffic sourced from the 172.16.0.0/21 destined to the 172.16.32.0/21 needs to be PAT to the IP address of the DMZ2 interface.
-traffic sourced from the 172.16.28.0/24 destined to the 172.16.0.0/21 needs to be translated as itself (identity translated).
-traffic sourced from the 172.16.32.0/21 destined to the 172.16.0.0/21 needs to be translated as itself (identity translated)
itself (identify translated).
I am confused on how the static and nat statement work. If static works both ways, then a policy
static should achieve the one way different required? Thanx.
05-03-2005 01:26 PM
Do not use NAT 0 with static, because NAT 0 will overrule static and static will not work properly. If you try to implement both NAT 0 and Static then you will certainly face issues between internal hosts communicating to dmz. Instead of using NAT 0 along with static, What I would recommend you is to use Static Nat (self-translation for each host) for which you don't want the address to get translated when it reaches the DMZ.
