07-18-2008 08:08 AM - edited 03-09-2019 09:07 PM
When I enter the "reload" command, Cisco ASA 5510 asks me
a question: System config has been modified Save? [Y]es/[N]o:
All I did was issuing a few "show" commands before the "reload" command. I definitely need to find out what
has been modified before the reboot
Is there any way to find out what has been modified to the running configuration.
Thanks!
07-18-2008 03:40 PM
Hi David
The steps I would be doing is:
1, show start
2, capture text
3, save to a text file (named startup)
4, show run
5, capture text
6, save to a text file (named runing)
Download a program called examdiff, you will then be able to compare the 2 files.
Regards MJ
07-21-2008 06:25 AM
If you want to know when changes are made, but don't want to setup TACACS (and you have a syslog server setup), you can have the router syslog all commands entered while in config mode:
devcorert01#conf t
devcorert01(config)#archive
devcorert01(config-archive)#log config
devcorert01(config-archive-log-cfg)#hidekeys
devcorert01(config-archive-log-cfg)#logging enable
devcorert01(config-archive-log-cfg)#notify syslog
Anytime someone enters any command while in config mode, the command will be sent to your syslog server.
Examples:
Jul 21 10:15:41 EDT: %PARSER-5-CFGLOG_LOGGEDCMD: User:console logged command:do sh run
Jul 21 10:17:33 EDT: %PARSER-5-CFGLOG_LOGGEDCMD: User:console logged command:interface GigabitEthernet2/2
Jul 21 10:17:38 EDT: %PARSER-5-CFGLOG_LOGGEDCMD: User:console logged command:shutdown
Jul 21 10:17:42 EDT: %PARSER-5-CFGLOG_LOGGEDCMD: User:console logged command:no shutdown
Note the "do show run". Even thought that is not a config command per se, it was entered while in config mode. Also notice the user is "console". If it was from a telnet session, you would see
Jul 21 10:17:33 EDT: %PARSER-5-CFGLOG_LOGGEDCMD: User:unknown user logged command:interface GigabitEthernet2/2
Jul 21 10:17:38 EDT: %PARSER-5-CFGLOG_LOGGEDCMD: User:unknown user logged command:shutdown
Jul 21 10:17:42 EDT: %PARSER-5-CFGLOG_LOGGEDCMD: User:unknown user logged command:no shutdown
Mike
07-21-2008 07:25 AM
Enter the following on the CLI:
show archive config differences nvram:startup-config system:running-config
Lines preceded with "+" are only found in the running-config. Lines preceded with "-" are absent from the running-config (i.e.: only found in the startup-config).
07-22-2008 05:29 AM
In ASA if you are doing tacacs command accounting then it will logs only those command that change the running config.
Since show command do not change any config , so it won't be reported by tacacs.
~JG
07-22-2008 10:44 AM
Re: My post above.
Lost sight of the fact that you were using an ASA. Sorry about that.
... would be useful on an IOS device.
