02-15-2002 09:38 AM - edited 03-08-2019 09:50 PM
Hi, am wondering whether Cisco supports Nested tunneling?! i mean Tunnel inside Tunnel ( IPSec - 3DES). Any body has got any idea?
Host A --> RouterA --> Concentrator 3030 -->PIX515 -->RouterB -->HostB
The Outer Tunnel is between Concentrator 3030 and PIX515 and the Inside Tunnel is between RouterA and Router B.
02-15-2002 11:17 AM
I don't know whether it is "supported", but it can be done.
We do it for encapsulating IPX through our VPN connections.
Just make sure you have matching 12.0 or later IOS on the routers. We had some problems with older versions and version mismatches.
02-19-2002 05:23 PM
It is possible.. A lot of ppl do that for GRE and IPSEC tunnels
02-22-2002 03:00 PM
Could you please explain... I tried it but the tunnell is not getting established between Router A and Router B when i try to pass through the VPN concentrator and PIX's tunnel.
02-22-2002 09:40 PM
yes cisco supports this.. see this link for
ideas
http://www.cisco.com/warp/public/707/index.shtml
bottom line is im fairly sure any IP traffic (ESP, etc) will work over a tunnel (providing you are not filtering anything on the outer tunnel)
02-23-2002 07:52 AM
The concentrator does not seems to be passing the trafic when i initiate the tunnel from Router A side though i configured to allow all traffic.(My privte interface (internal) filter is any any..) Do you have any ideas?!!
03-03-2002 07:37 PM
Finally I found a solution for this problem with a help of Cisco TAC. VPN 3060 does not pass IPSec traffic through inside interface. But when we tried with Cisco Router, it worked fine. Cisco says that, in theory VPN 3060 suppose to work in my scenario, however it didnt. I hope Cisco will come out with a Solution. ( I dont know whether it is a bug or not?!!)CISCO! PLEASE MAKE AN ATTENTION TO THIS...
