12-02-2017 09:54 PM - edited 03-10-2019 12:56 AM
HI All,
We are observing below vulnerability in WLC(AIR-CT5508-K9)
Product Version : 8.2.151.0
TLS/SSL Server Does Not Support Any Strong Cipher Algorithms |
Weak Cryptographic Key |
TLS/SSL Server Supports The Use of Static Key Ciphers |
Self-signed TLS/SSL certificate |
Untrusted TLS/SSL server X.509 certificate |
SHA-1-based Signature in TLS/SSL Server X.509 Certificate |
X.509 Certificate Subject CN Does Not Match the Entity Name |
Please suggest . Thanks !!
Solved! Go to Solution.
12-03-2017 02:12 AM
There is still something you could do here:
But as always, be aware of the consequences (at least with "2.") ...
12-03-2017 12:15 AM
Go HERE.
12-03-2017 02:12 AM
04-01-2021 12:41 AM
HI Team,
Anyone could help me on this?
We are Also observing below vulnerability in WLC(AIR-CT2504-K9)
Product Version : 8.5.160.0
Appreciate your prompt response. TIA!
07-04-2021 12:51 AM
can you help on how to fix this vulnerability on cisco WLC "Weak Cryptographic Key" .
