04-09-2006 11:17 PM - edited 03-09-2019 02:33 PM
Hi, Is there a way to configure a one way Static NAT. What i mean here is that any outside to inside communication must use this NAT, but not the other way around.
Basically, i have a requirement, where i would like to map two public IP to one private IP. Obviously PIX doesnt allow it, because it would be confused for traffic from inside to outside. If i am not interested in the translation from inside to outside to happen, is it possible to use one way static NAT, i.e, only for outside to inside..?
04-09-2006 11:46 PM
this seems a little tricky given the fact, that IP communication usually is bidirectional. So you cannot avoid inside to outside traffic. And this traffic needs to be NATed otherwise connectivity can not be achieved. So NAT or PAT in both directions is always required.
Have you tried port redirection "Using the Static Command for Port Redirection"
Hope this helps! Please rate all posts.
Regards, Martin
04-10-2006 12:40 AM
In fact, i was trying this with Port redirection. It does not help.
04-10-2006 03:01 AM
This is not possible,because TCP based connections are always have to have 3-way handshake before it pass the traffic. Once it done the handshake thats it.
Port Direction will be the same.
Hope its clear form you.
Thilanka
