05-26-2006 12:10 PM - edited 03-09-2019 03:02 PM
i found an ACL missing from outside n/w to inside n/w access.pls explain the case
static (outside,inside)123.0.0.2 123.0.0.2 netmask 255.255.255.255 0 0
05-26-2006 05:13 PM
Hi Aksher,
I think your other post (nat 0) related to this question.. :)
The statement is to map your inside host to external address, but in this case, it will actuall skip any
translation. This will allow outsider to access your internal host using internal host physical (original) IP Address - no translation.
But your [static (outside,inside) 123.0.0.2 123.0.0.2 netmask 255.255.255.255 0 0] statement need ACL on your outside interface to allow & control incoming traffic/access to the internal host.
Example:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_v52/config/examples.htm#xtocid4
Rgds,
AK
05-27-2006 04:27 AM
this is a diff.case.
but the inside int is on high sec. level thna the outside int. then why is the statis from inside to outside.
05-27-2006 06:31 PM
There are 2 secnarios where you need to use that command.
If you need to allow access from lower security to higher using higher host/network original IPs, for example, DMZ to Inside, then you need it.
static (inside,dmz) 10.1.1.0 10.1.1.0 netmask 255.255.255.0
Common method to allow lower to access higher is to use static mapping where you need to map inside host to an IP belongs to lower security segment IP:
inside: 10.1.1.0/24
DMZ: 10.1.10.0/24
static (inside,dmz) 10.1.10.100 10.1.1.100 netmask 255.255.255.255
* You need this to allow DMZ host to access inside host (10.1.1.100) as 10.1.10.100, which logically make it (10.1.1.100) looks like sitting in DMZ.
This is also mentioned in config without NAT example in the url - http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_v52/config/examples.htm#xtocid4. Cisco PIX also allows the same static command to be used in this scenario:
static (dmz,outside) 209.165.201.19 209.165.201.19
netmask 255.255.255.248
Also applicable if your inside segment run on public IP, you can either used NAT 0 (no translation) or the above static command.
Rgds,
AK
