Overlapping Static
Muhammad.Sajid
Community Member
Hello all,
I would like to know if I can configure static commands with overlapping addresses and it works. For e.g. if I have an a­ddress that is already covered in a net static statement like:
static (inside,outside) 192.168.10.0 192.168.10.0 netmask 25­5.255.255.0 0 0
but for one specific host I would like to specify the number­ of connections that this host can open by:
static (inside,outside) 192.168.10.50 192.168.10.50 netmask 255.255.255.255 500 0
After putting the second statement, it is noticed that PIX w­ould take it with a warning/error of overlapping addresses but won't t­ake the
"netmask" keyword. But how would I make sure that it is act­ually using my second statement for this particular host???
Has anyone tried this before. Please let me know your exper­ience.
Thanks in advance.
Atif
scoclayton
Level 11
Level 11
Static statements are read in a top down fashion. Try putting your more specific static higher in the configuration than your network static and see if that helps. This will probably require that you remove both statements from the config, do a 'cl xlate', and then add the statements back in the order specified above.
Let me know if this doesn't help.
Scott
As Scott said, statics are read top-down. If you do as he says and put the more specific one in first, then the PIX doesn't complain and it should work fine. Here's output from my PIX showing you can add them in:
sv-2-3(config)# sho static
static (inside,outside) 192.168.10.0 192.168.10.0 netmask 255.255.255.0 0 0
Now, as to whether it'll actually work the way you want it to, I haven't tested. There shouldn't be any reason why it wouldn't work though.
csoans
Atif,
Is this a typo or is this exactly what was typed into the pix
if this is the case make sure you change it to the line shown below and you should be fine
static (inside,outside) 192.168.10.50 192.168.10.50 netmask 255.255.255.255 0 0
No its not typo because I want to specify the number of connections that this host can open at one time.
However, I have tested it by changing the sequence and it worked for me.
So thanks for all your suggestions and help.
