SSH does not work after trying PDM
pslavkovsky
Level 3
Level 3
Hi.
I used SSH to access on PIX.
I tried use today PDM. PDM is nice thing 🙂 but I decide that I will stay with command line by SSH.
But after closing PDM my SSH connection does not work OK, connection is not established.
I found in syslog this message:
%PIX-6-315011: SSH session from <my IP addr> on interface outside for user "" disconnected by SSH server, reason: "TCP connection closed" (0x03)
Can You help me?
Peter
steven.wilson
Level 4
Level 4
It may be that you have accidentaly enabled the SSH connection to be authenticated either locally or by radius, but no usernames exist in that list to be authenticated against. By default the username is PIX and the password cisco. If you have changed the password or the user authentication, you will not get in using the default details.
Cheers,
Steve
