Passing EIGRP
jgmitter
Level 4
Level 4
I have a router a on either side of the pix that need to pass eigrp and igrp to each other. I understand the pix by default blocks multicast, documenatioin states setting up neighbor statements on the routers. Any notes, configs, or expereiences seen with this situation?
rrbleeker
Your best bet is to use GRE tunnels between the 2 routers and exchange (E)IGRP traffic between the routers via the tunnel.
From a security point of view it is not recommended to use this solution, but I guess that you might not have a choice.
