Passing EIGRP
jgmitter
Visitor
I have a router a on either side of the pix that need to pass eigrp and igrp to each other. I understand the pix by default blocks multicast, documenatioin states setting up neighbor statements on the routers. Any notes, configs, or expereiences seen with this situation?
rrbleeker
Level 5
Level 5
Your best bet is to use GRE tunnels between the 2 routers and exchange (E)IGRP traffic between the routers via the tunnel.
From a security point of view it is not recommended to use this solution, but I guess that you might not have a choice.
