PDM access required on low security level segment
gatekeeper
Just upgraded my PIX 525 (with failover) to 6.2(2).
Would want to use PDM access but not coming from "inside" interface but from a lower security level(95). How do I do this? Following procedures from docs got error when I specified IP address not on "inside". I have 5 segments on my pix ( outside, segment1, segment2, segment3, segment4, inside) and I want to use segment4. Thanks a lot.
gatekeeper
gfullage
You can certainly do this. All you should need is (assuming 1.1.1.1 is on segment4):
> http 1.1.1.1 255.255.255.255 segment4
The docs here (http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_62/cmdref/gl.htm#xtocid4) show an example on the outside interface.
First I entered the ff:
>http server enable
and then I ran "setup".
>gatekeeper1(config)# setup
>Pre-configure PIX Firewall now through interactive prompts [yes]?
>Enable password []:
>Clock (UTC):
> Year [2002]:
> Month [Jul]:
> Day [30]:
>Time [14:22:27]:
> Inside IP address [2.2.2.2]: NOTE: I entered the "inside" IP address here
>Inside network mask [255.255.255.0]:
>Host name [gatekeeper1]:
>Domain name [gatekeeper.com]:
>IP address of host running PIX Device Manager: 1.1.1.1 NOTE: segment4 IP
>Use this configuration and write to flash? yes
>Building configuration...
When I did a "sh run", I got this:
>http server enable
>http 1.1.1.1 255.255.255.255 inside
This doesn't look good! I access using 1.1.1.1. I authenticated successfully
but got a "404" error. I think I am doing something terribly stupid ;-)
Thanks.
