10-24-2003 08:52 AM - edited 03-09-2019 05:16 AM
Is there a way to reload a PIX from the PDM CLI?
If so could someone tell me the comand Combination?
The only way I can reach this device is via the PDM from my current location.
Thanks all,
Duane
10-24-2003 09:52 AM
reload is the CLI command to do it, does that work?
10-25-2003 07:26 PM
Reload in the command, but after you type reload you are asked to confirm. If you type yes it's an invalid command.
