10-08-2003 11:36 AM - edited 03-09-2019 05:04 AM
I am looking to see what outbound ports and inbound ports I need to block to make this "feature of the internet" unavailable. I want to block these ports. Anyone know what ports they are or where I can find them?
Solved! Go to Solution.
10-08-2003 12:17 PM
Search for ports used by H323. Particularly these ports need to be blocked 1720/tcp/udp,1718/udp,1719/udp
check the following link for more information
http://www.bcr.com/bcrmag/2002/07/p10.asp
Nadeem
10-08-2003 12:17 PM
Nadeem
10-26-2003 02:12 AM
Nadeem i would appreciate if you let me know what is the application of ports 1414 and 4848 , how to enable on pix as am getting problem with fixup command .....
Azhar
