08-10-2006 04:36 AM - edited 03-09-2019 03:51 PM
Does anyone know how to transparently force http traffic from some hosts (inside subnet 10.3.0.0/16) on one interface of a Cisco PIX firewall through a proxy server?
08-10-2006 06:17 AM
As far as i know, it is not possible. It is not the role of PIX.
The proxy redirection should happen at the client end ( in the browser configuration..)
Refer to a similar thread posted today..
-VJ
08-10-2006 07:28 AM
hi u cannot redirect http traffic for a proxy server but u can surely redirect them for a url-filtering server. by the way if u are using the proxy for authentication of clients for http sites. u can configure that also on the pix.
if u want the users should have access the proxy first before accessing a website u will have to place the proxy server before the pix. this will dpend how many interfaces u are using in the proxy server.
give us more info to sort out this issue.
regards
sebastan
08-15-2006 11:06 PM
WCCP is supported on PIX version 7.2. You can utilise this feature if your transparent proxy support WCCP as well.
