port redirection overlapping
g.rodegari
This combination of nat should works well?
static (inside,outside) tcp interface 80 10.10.10.10 5800
static (inside,outside) tcp interface 123 10.11.11.11 6700
nat (inside) 1 10.0.0.0 255.0.0.0
global(outside) 1 interface
thanks,
Graziano
wdrootz
Level 4
Level 4
Looks good at a glance. Is there a specific problem you’re trying to find?
I only know if is possible to use the keyword "interface" in a static command and in a global command at the same time...
Graz.
