PPTP to cisco2600 with same address pool as Local LAN?
tkpsimon
I have created PPTP and VPNclient3.5.2 to cisco 2600, can i use the same Local LAN address on the address pool for the outside client?
any suggestion would be appreciate.
vijkrish
Is the question of using same pool for the VPN client connection or for PPTP connection ? For VPN client connection, yes, For PPTP haven't tested it.
btw, as these are internal RFC1918 addresses that you normally define,
best bet is to use seperate pool anyway.
Hope this helps,
Vijay
