Privilege level information
gerardor884
does someone knows what is the detail information of privilege levels 0 to 15?
what does privilege level 3?
what does privilege level 7?
 what does privilege level 15?
I am looking for the most basic level that permits show commands such as show ip route, show ip bgp summary, show cdp neighbors
2 Accepted Solutions
Francesco Molino
Privilege 15 means admin with full rights. Privilege 1 is user-level command only. Everything in between is up to you to configure on the switch to device what privilege can access what command. If you assign privilege 4 and commands for this privilege aren't defined, ios will go to lower privileve until it get one configured. This means, if you didn't configure any privilege and assign level 4 to a user, it will check 3 then 2 and finally 1 and assign level 1 commands to your user.
If you had configured 3, then commands 3 were assigned.
Privilege 0 has only few command.
Take a look here:
https://learningnetwork.cisco.com/docs/DOC-15878
https://www.cisco.com/c/en/us/support/docs/security-vpn/terminal-access-controller-access-control-system-tacacs-/23383-showrun.html
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
7 Replies 7
alex it looks like the URL that you just provided is broken
I just checked the new one and it works.
Francesco Molino
Take a look here:
Francesco
Thank you !
You're welcome
Francesco
