Problem accessing internal IIS web server
l4nier
Please let me start by saying I am a newbie. I apologize in advance for stupid questions.
My problem is this. I have setup static and conduit statements in my pix to access an internal web server. I am using the same format as is used for other boxes (ftp and www) that are accessed from outside the network. These work fine but I can't access my new web box.
I did a little bit of troubleshooting and it looks like packets are getting past my router but timing out when it gets to the pix.
In my logs I am getting the following error:
Deny inbound (No xlate) tcp src outside:61.94.56.23/80 dst outside:216.191.146.83/2796
I wasn't sure why it was trying to come through on /2796. Also important to note here is the address 216.191.14.83 is the IP for my global (outside). It is not the IP address that I am trying to reach, which is 216.191.220.147/
Any ideas on where I can begin to troubleshoot this problem?
Thanks in advance.
Louanne
lfournier@nexterna.com
10 Replies 10
nkhawaja
Please share the configs (change/hide the IP addresses).
The log message that you are referring may not be related to your issue.
Nadeem Khawaja
Ok thank you. Here it is. I hope I haven't hidden the IPs so much that you can't make sense of it. Please let me know.
Thanks.
Louanne
: Saved
: Written by enable_15 at 19:55:32.803 UTC Tue Feb 17 2004
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security50
enable password encrypted
passwd encrypted
hostname
domain-name nexterna.com
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol pptp 1723
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
no fixup protocol smtp 25
fixup protocol sqlnet 1521
names
access-list 101 permit ip 192.168.20.0 255.255.255.0 172.16.0.0 255.255.0.0
access-list 101 permit ip 192.168.10.0 255.255.255.0 172.16.0.0 255.255.0.0
access-list 102 permit ip 192.168.10.0 255.255.255.0 172.31.0.0 255.255.0.0
access-list nonat permit ip 192.168.20.0 255.255.255.0 172.16.0.0 255.255.0.0
access-list nonat permit ip 192.168.20.0 255.255.255.0 192.168.50.0 255.255.255.0
access-list nonat permit ip 192.168.50.0 255.255.255.0 192.168.20.0 255.255.255.0
access-list nonatdmz permit ip 192.168.10.0 255.255.255.0 192.168.50.0 255.255.255.0
access-list nonatdmz permit ip 192.168.10.0 255.255.255.0 172.31.0.0 255.255.0.0
access-list nonatdmz permit ip 192.168.10.0 255.255.255.0 172.16.0.0 255.255.0.0
access-list 100 permit ip 192.168.20.0 255.255.255.0 192.168.50.0 255.255.255.0
access-list 100 permit ip 192.168.10.0 255.255.255.0 192.168.50.0 255.255.255.0
access-list 103 permit ip 192.168.20.0 255.255.255.0 172.16.3.0 255.255.255.0
access-list 103 permit ip 192.168.10.0 255.255.255.0 172.16.3.0 255.255.255.0
pager lines 24
logging on
logging timestamp
logging console debugging
logging trap warnings
logging history warnings
logging host inside 192.168.20.3
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip address outside xxx.xxx.xxx.xxx.82 255.255.255.248
ip address inside 192.168.20.1 255.255.255.0
ip address dmz 192.168.10.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool burlingtonpool 192.168.50.1-192.168.50.50
no failover
failover timeout 0:00:00
failover poll 15
no failover ip address outside
no failover ip address inside
no failover ip address dmz
pdm location 172.16.9.2 255.255.255.255 inside
pdm location 192.168.20.4 255.255.255.255 inside
pdm location 192.168.20.5 255.255.255.255 inside
pdm history enable
arp timeout 14400
global (outside) 1 xxx.xxx.xxx.xxx netmask 255.255.255.248
nat (inside) 0 access-list nonat
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
nat (dmz) 0 access-list nonatdmz
nat (dmz) 1 0.0.0.0 0.0.0.0 0 0
static (dmz,outside) xxx.xxx.xxx.xxx 192.168.10.30 netmask 255.255.255.255 0 0
static (dmz,outside) xxx.xxx.xxx.xxx192.168.10.100 netmask 255.255.255.255 0 0
static (inside,dmz) 192.168.20.0 192.168.20.0 netmask 255.255.255.0 0 0
static (dmz,outside) xxx.xxx.xxx.xxx192.168.10.41 netmask 255.255.255.255 0 0
static (inside,outside) xxx.xxx.xxx.xxx192.168.20.9 netmask 255.255.255.255 0 0
static (inside,outside) xxx.xxx.xxx.xxx192.168.20.64 netmask 255.255.255.255 0 0
static (inside,outside) xxx.xxx.xxx.xxx192.168.20.12 netmask 255.255.255.255 0 0
conduit permit icmp any any
conduit permit tcp host xxx.xxx.xxx.xxxeq ftp any
conduit permit tcp host xxx.xxx.xxx.xxxeq www any
conduit permit tcp host xxx.xxx.xxx.xxx eq https any
conduit permit tcp host xxx.xxx.xxx.xxx eq smtp any
conduit permit tcp host xxx.xxx.xxx.xxxeq pop3 any
conduit permit tcp host xxx.xxx.xxx.xxx eq www any
conduit permit tcp host xxx.xxx.xxx.xxxeq https any
conduit permit udp any eq isakmp host xxx.xxx.xxx.xxx
conduit permit ah host xxx.xxx.xxx.xxx any
conduit permit esp host xxx.xxx.xxx.xxxany
route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
aaa-server vpnauth protocol radius
aaa-server vpnauth (inside) host 192.168.20.3 nex6818terna timeout 20
aaa-server auth protocol radius
aaa-server auth (inside) host 192.168.20.3 nex6818terna timeout 20
aaa authentication telnet console auth
http server enable
http 192.168.20.4 255.255.255.255 inside
http 192.168.20.39 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
tftp-server inside 192.168.20.35 /
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set NexternaSet esp-des
crypto ipsec transform-set burlington esp-des esp-md5-hmac
crypto ipsec transform-set norcom esp-des esp-md5-hmac
crypto dynamic-map burldynmap 20 set transform-set burlington
crypto map CanadaMap 5 ipsec-isakmp
crypto map CanadaMap 5 match address 103
crypto map CanadaMap 5 set peer 64.233.31.178
crypto map CanadaMap 5 set transform-set NexternaSet
crypto map CanadaMap 15 ipsec-isakmp
crypto map CanadaMap 15 match address 102
crypto map CanadaMap 15 set peer 12.26.74.85
crypto map CanadaMap 15 set transform-set norcom
crypto map CanadaMap 20 ipsec-isakmp dynamic burldynmap
crypto map CanadaMap client authentication vpnauth
crypto map CanadaMap interface outside
isakmp enable outside
isakmp key nexterna6818 address 12.26.74.85 netmask 255.255.255.255 no-xauth no-config-mode
isakmp key nex6818terna address 65.112.203.34 netmask 255.255.255.255 no-xauth no-config-mode
isakmp key burlingtonvpn address 0.0.0.0 netmask 0.0.0.0
isakmp key Nexterna6818 address 64.233.31.178 netmask 255.255.255.255 no-xauth no-config-mode
isakmp identity address
isakmp policy 5 authentication pre-share
isakmp policy 5 encryption des
isakmp policy 5 hash md5
isakmp policy 5 group 2
isakmp policy 5 lifetime 86400
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 1
isakmp policy 10 lifetime 86400
vpngroup burlington address-pool burlingtonpool
vpngroup burlington dns-server 192.168.20.3
vpngroup burlington wins-server 192.168.20.3
vpngroup burlington default-domain canada.nexterna.com
vpngroup burlington split-tunnel 100
vpngroup burlington idle-time 1800
telnet 192.168.20.0 255.255.255.0 inside
telnet timeout 15
ssh 0.0.0.0 0.0.0.0 outside
ssh 192.168.20.0 255.255.255.0 inside
ssh 0.0.0.0 0.0.0.0 inside
ssh 0.0.0.0 0.0.0.0 dmz
ssh timeout 10
console timeout 0
terminal width 80
Cryptochecksum:xxxxx
: end
My bet, hiding the IPs are making it more difficult to conclude, please send the config unicast to nkhawaja@cisco.com
Nadeem
Nadeem
Nadeem
jackko
Level 7
Level 7
the debug doesn't indicate much, as it could be an attack from the internet.
would you mind posting the config
firstly there is bug with 6.3(1) regarding to nat, i would suggest you to upgrade the os
secondly do a sh xlate and check whether or not there is an entry for the new server
Can you tell me what version I should be at and where I can get the files?
Thanks!
Louanne
6.3(3) is the one. below is the url and i believe you need a vaild cco login
http://www.cisco.com/cgi-bin/tablebuild.pl/pix
