Problem Adding IDS in VMS 2.2
talha_490
i am trying to add the IDS 4215 and IDSM module which is giving me the following error.
This sensor is version 4.1(4)S119 which is not known to the system. Install a Signature update to the system and retry
the procedure which i have followed is
1. Install common services
2. install ids MC and Security Monitor
3. Install update 1 for VMS
then i tried to add the devices.
i am attaching the image of error. i have erase the name due to security reasons
drolemc
Level 6
Level 6
Make sure that you the signature level of the Sensor that you are trying to add is in the path C:\Program
Files\CSCOpx\MDC\etc\ids\updates on the VMS server. Next, log into IDSMC and go to Configuration | Updates | Update Network IDS Signatures and Apply this signature level. Then go to devices | Sensor and try to add then new sensor
and make sure you checked "Discover Settings".
Try this link:
http://www.cisco.com/en/US/products/sw/cscowork/ps2330/products_qanda_item09186a00801dac10.shtml
