I am using the configurations given in the following link
http://www.cisco.com/en/US/partner/netsol/ns110/ns170/ns171/ns27/networking_solutions_white_paper09186a008018914d.shtml
But i am not able to see the IPSec SAs in the routers.
The output of sh crypto ipsec client ezvpn has the following
CLIENT#sh crypto ipsec client ezvpn
Easy VPN Remote Phase: 2
Tunnel name : simplevpn
Inside interface list: FastEthernet0/0,
Outside interface: Serial0/1
Current State: SS_OPEN
Last Event: SOCKET_READY
Mask: 255.255.255.255
Default Domain: cisco.com
I am not finding where i am going wrong......
SERVER#sh run
Building configuration...
Current configuration : 1923 bytes
version 12.2
hostname SERVER
logging queue-limit 100
enable password cisco
username xxx password xxxx
aaa new-model
aaa authentication login loginlist local
aaa authorization network loginlist local
aaa session-id common
ip subnet-zero
ip audit notify log
ip audit po max-events 100
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp xauth timeout 60
crypto isakmp client configuration group vpngroup
key vpnkey
domain cisco.com
crypto ipsec transform-set vpnset esp-3des esp-sha-hmac
crypto dynamic-map vpnmap 1
set transform-set vpnset
crypto map vpnmap client authentication list loginlist
crypto map vpnmap isakmp authorization list loginlist
crypto map vpnmap client configuration address respond
crypto map vpnmap 1 ipsec-isakmp dynamic vpnmap
no voice hpi capture buffer
no voice hpi capture destination
mta receive maximum-recipients 0
controller T1 2/0
framing sf
linecode ami
controller T1 2/1
framing sf
linecode ami
interface FastEthernet0/0
ip address xx.xxx.152.221 255.255.255.128
duplex auto
speed auto
crypto map vpnmap
interface Serial1/0
no ip address
shutdown
serial restart_delay 0
no fair-queue
interface Serial1/1
ip address xxx.xxx.xxx.2 255.255.255.0
crypto map vpnmap
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface FastEthernet2/0
no ip address
shutdown
duplex auto
speed auto
ip http server
no ip http secure-server
ip classless
radius-server authorization permit missing Service-Type
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
end
sh run
Current configuration : 980 bytes
version 12.2
hostname CLIENT
username cisco password 0 cisco
ip subnet-zero
ip audit notify log
no ftp-server write-enable
crypto ipsec client ezvpn simplevpn
connect auto
group vpngroup key 0 vpnkey
mode client
peer 100.100.100.2
ip address xx.xx.20.1 255.255.255.0
speed auto
crypto ipsec client ezvpn simplevpn inside
interface Serial0/0
no ip address
shutdown
no fair-queue
interface Serial0/1
ip address xxx.xxx.xxx.1 255.255.255.0
clockrate 64000
interface ATM1/0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
no scheduler allocate
end
-Deepu
