Problem with LILO to loading the OS
Hello everyone.
We have a problem with LILO to loading the OS in a CS-MARS 110R, find attached a screenshot.
The only solution is recovery the MARS Operating System.
Thanks in advance.
Antonio
mwinnett
Level 3
Level 3
Antonio, if the boot process stops there, then you will have to try and re-image the mars. Matthew
Hi Matthew.
The re-image was impossible because this CS-MARS didn´t read the DVD correctly (hardware error) and we asked to Cisco a RMA.
Antonio
OK, thanks for the feedback. Its always worth trying to re-image before
replacing h/w
matthew
