"AnalysisEngine busy" prevents upgrade IDS4235 from 4.0(1)S37 to 4.1(4)S91
yulan.lee
My IDS-4235 is having BIOS of A04, currently running 4.0(1)S37. I want to upgrade it to IDS-K9-sp-4.1-4-S91. However, the error message from AnalysisEngine abort the processing every time. (See Error message at the bottom.) I have waited minutes and hours for the retries, same result. Is there anything that I need to do to get this working???
Phoenix ROM BIOS PLUS Version 1.10 A04
Cisco Systems IDS-4235/4250
IDS-4235/4250
Embedded server management firmware revision 1.56
Backplane firmware revision 0.29
One 1266 MHz Processor, Processor Bus: 133 MHz, L2 cache: 512 KB
Adaptec AIC-7899 SCSI BIOS Build 25309
(c) 1999 Adaptec, Inc. All Rights Reserved.
Press <Ctrl><A> for SCSISelect(TM) Utility!
Ch A, SCSI ID: 0 SEAGATE ST318453LC 160
SCSI ID: 6 PE/PV 1x3 SCSI BP ASYN
sensor# show version
Application Partition:
Cisco Systems Intrusion Detection Sensor, Version 4.0(1)S37
OS Version 2.4.18-5smpbigphys
Platform: IDS-4235
Sensor up-time is 1 min.
Using 223019008 out of 1055744000 bytes of available memory (21% usage)
Using 544M out of 15G bytes of available disk space (4% usage)
MainApp 2003_Jan_23_02.00 (Release) 2003-01-3T02:00:25-0600 Running
AnalysisEngine 2003_Jan_23_02.00 (Release) 2003-01-3T02:00:25-0600 Running
Authentication 2003_Jan_23_02.00 (Release) 2003-01-3T02:00:25-0600 Running
Logger 2003_Jan_23_02.00 (Release) 2003-01-3T02:00:25-0600 Running
NetworkAccess 2003_Jan_23_02.00 (Release) 2003-01-3T02:00:25-0600 Running
TransactionSource 2003_Jan_23_02.00 (Release) 2003-01-3T02:00:25-0600 Running
WebServer 2003_Jan_23_02.00 (Release) 2003-01-3T02:00:25-0600 Running
CLI 2003_Jan_17_18.33 (Release) 2003-01-7T18:33:18-0600
Upgrade History:
IDS-K9-maj-4.0-1-S36 15:32:52 UTC Thu Jan 30 2003
Recovery Partition Version 1.1 - 4.0(1)S37
sensor#
sensor(config)# upgrade ftp://ids@10.1.1.254//IDS-K9-sp-4.1-4-S91.rpm.pkg
Password: *********
Warning: Executing this command will apply a service pack to the application parititon. The system may be rebooted to complete the upgrade.
Continue with upgrade? : yes
Broadcast message from root (Thu Sep 30 12:14:38 2004):
Applying update IDS-K9-sp-4.1-4-S91.
Shutting down all CIDS processes. All connections will be terminated.
The system will be rebooted upon completion of the update.
Error: AnalysisEngine is currently busy and unable to process this update. Please wait several minutes before attempting update again.
marcabal
This looks like an incorrect error message.
I think the installation is coming across an error and is spitting out the wrong error message, the real error message should have been that the 4.1(1) Minor Update package has to be installed before you install the 4.1(4) Service Pack.
You can download the 4.1(1) Minor Update from:
http://www.cisco.com/cgi-bin/tablebuild.pl/ids4
You can't install 4.1(4) on top of 4.0(1).
I tried 4.1(1). Got different error message. It failed to download from my FTP server. (I'm sure the ftp password is correct and file does exist on the ftp server.) Instead, it looked at its own HD for the OS.
sensor# conf t
sensor(config)# upgrade ftp://ids@10.1.1.254//IDS-K9-min-4.1-1-S47.rpm.pkg
Password: *********
Warning: Executing this command will apply a minor version upgrade to the applic
ation partition. The system may be rebooted to complete the upgrade.
Error: download file does not exist: /usr/cids/idsRoot/var/updates/IDS-K9-min-4.
1-1-S47.rpm.pkg
sensor(config)#
This error occurs because the download was unsuccessful, but the sensor was unable to tell that download failed. So the sensor thinks that the file should be on the sensor and tries to execute and you wind up with the error that you saw.
We have seen these happen for a couple of different reasons:
1) The ftp server does not have the standard prompts.
The sensor is hardcoded to look for certain ftp prompts, if your ftp server used different prompts then the download will timeout not being able to recognize the prompts.
You may also want to try using a server from this list:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/csids/csids8/13870_01.htm#xtocid34
NOTE: The prompt checking has been improved in the 4.1(4) Service Pack, but as you've seen you first half to get 4.1(4) loaded before you can take advantage of the improvements.
2) A timeout while downloading a large file. The 4.1(1) Minor Version upgrade is a fairly large file. If the ftp server is busy, or is accessed through a busy network then the download can take to long and will timeout. We have seen this most often with upgrades being done from ftp servers being reached over the internet. To prevent this issue try to use a ftp server that is not very busy and is located on the same network as the sensor.
NOTE: In 4.1(4) this addressed by the addition of an ftp timeout parameter. In 4.0 and 4.1(1) the timeout was hardcoded, but in 4.1(4) the user can increase the timeout to allow for longer download times. But of course you have to first get 4.1(4) loaded to get this feature.
