Reflexive ACL Cisco 3750X
reashad
Does Cisco 3750x supports Reflexive ACL.
I am confused because I can configure it on the device but it is not working.
balaji.bandi
show version will help why it was not working. also check below document for limitation.,
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_58_se/configuration/guide/3750xscg/swacl.html
BB
here is the show version:
RH_core#show version
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.2(4)E2, R        ELEASE SOFTWARE (fc2)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 27-Jun-16 08:25 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(58r)SE1, RELEASE SOFTW        ARE (fc1)
RH_core uptime is 2 hours, 17 minutes
System restarted at 10:41:49 EST Tue Feb 2 2021
System image file is "flash:/c3750e-universalk9-mz.152-4.E2.bin"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750X-24P (PowerPC405) processor (revision A0) with 262144K bytes of m        emory.
Processor board ID FDO1751P060
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : B8:38:61:18:C3:00
Motherboard assembly number     : 73-12551-10
Motherboard serial number       : FDO175028PS
Model revision number           : A0
Motherboard revision number     : C0
Model number                    : WS-C3750X-24P-S
Daughterboard assembly number   : 800-32727-03
Daughterboard serial number     : FDO175100NP
System serial number            : FDO1751P060
Top Assembly Part Number        : 800-31325-08
Top Assembly Revision Number    : E0
Version ID                      : V05
CLEI Code Number                : COMJR00ARE
Hardware Board Revision Number  : 0x05
Switch Ports Model                     SW Version            SW Image
*    1 30    WS-C3750X-24P             15.2(4)E2             C3750E-UNIVERSALK9-        M
Configuration register is 0xF
RH_core#
