Renew HydrantID SSL ICA G2 Cisco ISE
I'm looking for some help, the following certificate will expire soon, so I need to know how can renew it or should I wait until it expires or can I delete it in a safe way?
Certificate: HydrantID SSL ICA G2
CISCO ISE 2.7 patch 9
KarthikeyanD
As per cisco team,  This cert not needed for the higher version. May be you can check with TAC for more detail
Trust Certificate: HydrantID SSL ICA G2
Functions the certificate had - ISE connected to Cisco.com via SSL to obtain binary and data updates for Posture and BYOD. On February 14th, 2018, Cisco renewed the certificate for that SSL connection. The new certificate has a root certificate signed by QuoVadis. Therefore, you can either let it expire or you can freely remove it if your ISE is version above 2.3.
You can also check this Field notice, where this exact change has been documented: https://www.cisco.com/c/en/us/support/docs/field-notices/701/fn70122.html In summary:
Since this certificate was used in ISE 2.3 to fix a specific issue connected with which is no longer present in future version, this certificate does not need renewal and can be either removed or left to expire.
KarthikeyanD
Thank you for your response!
