route issue
imranraheel
I have a server 1 PIX and 1 router in my lab all are connected to a switch with a dsl modem all have global IP's what i want to do is when the request to server from a particular ip is coming i want to direct it from my router and for all others ip i want my pix to act as gateway on router i have a vpn configured for VPN remote access but the issue is on my server the gateway is of pix so when ever i try to connect this server using vpn router it does not work
spremkumar
Level 9
Level 9
Hi Imran
Why cant you terminate the vpn tunnels onto your PIX firewall instead doing the same in your router ?
regds
ajagadee
Imran,
Correct me if I am wrong. If you are terminating the VPN Clients on the router and assigning IP Address via an IP Pool. Why dont you add a route in the server for the Pool of IP Addresses to point back to the router.
Arul
** Please rate all helpful posts **
thanks can u explain in detail plz
