Securing Internet Edge Switch
andy.winford
I am fairly familiar with hardening of Cisco routers acting as an internet gateway, like enabling SSH and blocking inbound access to private range IP addressing via ACLs, disabling , but what about switches?   Is there a best practice on configuring a switch that is being used as a L3 device for internet access?
Thanks...
Andy
mvsheik123
Level 7
Level 7
For L3 switch @ internet edge, you can use the similar security restrictions (ACLs, disabling services that is not needed etc) and inaddition 'admin down' the ports that are not being used. In addition to that if the switch IP not required to advertise to interenet, do not add the default route (you may need this incase of L3 behaviour, but you can judge better).
hth
MS
