05-02-2008 11:19 AM - edited 03-09-2019 08:38 PM
ive added an alias command on my pix and now i can only access the dns server via public ip 67.x.x.x - if alias is another name for something why cant i access the dns server by it's internal ip also 10.10.5.x?
i have to have two rdp connections for the same dns server - if i come in via vpn i have to use 10.10.5.x but if im inside i have to use 67.x.x.x - the server guys are complaining.
ideas?
thanks - Jerry
05-08-2008 07:38 AM
Try this example. Replace with your IP address
static (dmz,inside) translated_IP real_ip dns
ip address inside 10.1.1.1 255.255.255.0
ip address dmz 172.16.1.1 255.255.255.0
static (dmz,outside) x.x.x.x 172.16.1.5 netmask 255.255.255.255
static (dmz,inside) x.x.x.x 172.16.1.5 netmask 255.255.255.255 dns
For more info about alias Command for the Cisco Secure PIX Firewall
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094aee.shtml
05-08-2008 11:10 AM
after i read your reply this morning i was able to ping the internal ip in the dmz - 10.10.5.36 from inside 172.16.1.x with out any changes but as fast as it worked it stopped working again. i have this:
static (DMZ1,outside) 67.13.3.x 10.10.5.36 netmask 255.255.255.255
then i added this:
static (DMZ1,inside) 67.13.3.x 10.10.5.36 netmask 255.255.255.255
cleared xlate and i still couldnt ping it.
im stumped - Jerry
