Singlemode/multimode on Gigabit-interface Pix525?
hancisco
I have to move our Pix525, resulting in a long distance between the outside interface, which is a pix-1-GE-66, and our ISP.
The interface is now connected with a multimode-connection to the ISP-router, but in the new situation I will have to use a singlemode-connection because of the distance.
Can the pix-1-GE-66 interface handle this? If not is there an interface available to make this possible, or should I try to find a convertor from multi-mode to singlemode? If so, any suggestions?
Thanks for any reaction!
Han.
ywadhavk
Hi Han,
You will require to have a convertor of some sort. Don't know which one to reccommened as there are many vendors that offer these convertors.
yatin
