Bookmark
Subscribe
250
Split tunneling
bhatok
I need to enable split tunneling on a pix 515. Clients are using Cisco VPN Client 4.0.1 and need access to local network printers. Not sure how to go about this task. Does anyone have any config examples or links. Do I simply create an ACL and apply it with the vpngroup split tunnel command?
Brandon
gfullage
Yeah pretty much. All you should need is something like the following:
access-list 150 permit ip any
vpngroup split-tunnel 150
On the VPN client you will have to enable the "Allow Local LAN Access" checkbox.
