Static NAT issue
I have just installed my first FWSM at one of your internet pops. Pretty simple only inside and outside no dmz (all listed below). I had to put a static address translation so the internet router could talk back into the internal syslog and tacacs servers on the internal network (10.233.85.254 / 172.21.85.254) which works fine for the connections allowed inbound from the internet router. But when I try to access the internet from those two devices its not being routed because the pix is using the static address (10.233.85.254 / 172.21.85.254) to the internet router and it is not being routed after that. I know I can do an address translation to another one of my 162.119.0.0 address and this will work but I am trying to get around this because I have another Internet POP soon to change from Firewall-1 to PIX that will literally have 100(s) of these static address translations.
<------------------------snip---------------------->
global (outside) 1 162.119.64.110 netmask 255.255.255.0
global (outside) 2 162.119.64.111 netmask 255.255.255.0
global (outside) 3 162.119.64.112 netmask 255.255.255.0
global (outside) 4 162.119.64.113 netmask 255.255.255.0
global (outside) 5 162.119.64.114 netmask 255.255.255.0
global (outside) 6 162.119.64.115 netmask 255.255.255.0
global (outside) 7 162.119.64.116 netmask 255.255.255.0
global (outside) 8 162.119.64.117 netmask 255.255.255.0
global (outside) 9 162.119.64.100 netmask 255.255.255.0
nat (inside) 1 10.224.0.0 255.248.0.0 0 0
nat (inside) 2 10.232.0.0 255.248.0.0 0 0
nat (inside) 3 10.240.0.0 255.248.0.0 0 0
nat (inside) 4 10.248.0.0 255.248.0.0 0 0
nat (inside) 5 10.32.0.0 255.224.0.0 0 0
nat (inside) 6 10.64.0.0 255.224.0.0 0 0
nat (inside) 7 10.96.0.0 255.240.0.0 0 0
nat (inside) 8 10.112.0.0 255.248.0.0 0 0
nat (inside) 9 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 172.21.85.254 172.21.85.254 netmask 255.255.255.255 100 100
static (inside,outside) 10.233.85.254 10.233.85.254 netmask 255.255.255.255 100 100
Thanks for any help.
nkhawaja
For routing to the inetnet a public address is must. Either do translation on the FWSM or on the edge router.
You can try to make NAT0 work here
e.g. access-list 101 permit ip
nat (inside) 0 access-list 101
So it will be a translation only between the TWO IPs.
If the inside server wants to go to internet, it will be using NAT/Global
Nadeem
Nadeem thank you for the reply. But if the Edge router has to talk back to the inside server (say for AAA) won't I need a static for that translation? Then the static will over ride the global translation for the internal server out to the internet. I will give your recommendation a try to see how it works thanks.
Eric
sends
so here is the deal. Either make static conditional or make nat conditional. IF you have checked this url for policy NAT, it should work for your scenario.
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/config/bafwcfg.htm#1113601
Nadeem
