static PAT statements, need help...
dsingleterry
Hello all,
I am in the process of setting up an email server, for the time being for reasons I'd rather not explain, I cannot put it on the DMZ. So it is sitting on the inside of the 515e firewall interface.
I have the internal IP of that server as 192.168.50.13, and from inside the network I can send , receive, etc email on that server. It is a new server so I recently setup my A and MX records. When pinging the Domain entry the proper IP is now assigned to the Domain name. However I cannot see my email server from the outside world. When running a DNS query on the MX record I get no response.
The problem is at the PIX level. My static statements dont seem to be working.
One of my 4 static statements works, (for our Terminal Services server) but the other 3 entries do not.
They are as follows:
static (inside,outside) tcp MainOffice 3389 192.168.50.75 3389 netmask 255.255.255.255 0 0
static (inside,outside) tcp MainOffice smtp 192.168.50.13 smtp netmask 255.255.255.255 0 0
static (inside,outside) tcp MainOffice pop3 192.168.50.13 pop3 netmask 255.255.255.255 0 0
static (inside,outside) tcp MainOffice telnet 192.168.50.201 telnet netmask
255.255.255.255 0 0
(the last entry is just to test and see if I could even host a win2k standard telnet server from my local desktop and see it through the firewall, the test was unsuccessful, I can telnet in via the local IP, .201, but not via the outside IP, MainOffice.)
Since often other places in the PIX config seem to affect the issues I have :), I am including a full running-config listing below for those who would like to reference it. Thank you for your time,
One other strange thing of note, with this current config, I cannot ping my outside interface IP from either external IP's, or from internal IP's. I have my ICMP entries set and thought I should be able to see it, but cant. This isnt as important of an issue as the above issue.
Dave
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 intf2 security10
hostname YRPCI
domain-name yrpci.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
fixup protocol http 8080
fixup protocol ftp 22
names
name x.x.71.8 ConstOffice
name x.x.81.11 BftOffice
name x.x.71.7 MainOffice
access-list acl_outbound permit ip host 192.168.50.10 any
access-list acl_outbound permit ip host 192.168.50.75 any
access-list acl_outbound permit ip host 192.168.50.201 any
access-list acl_outbound permit ip host 192.168.50.202 any
access-list acl_outbound permit tcp host 192.168.50.203 any
access-list acl_outbound permit tcp host 192.168.50.204 any
access-list acl_outbound permit tcp host 192.168.50.205 any
access-list acl_outbound permit tcp host 192.168.50.206 any
access-list acl_outbound permit tcp host 192.168.50.207 any
access-list acl_outbound permit tcp host 192.168.50.208 any
access-list acl_outbound permit tcp host 192.168.50.209 any
access-list acl_outbound permit tcp host 192.168.50.210 any
access-list acl_outbound permit tcp host 192.168.50.211 any
access-list acl_outbound permit tcp host 192.168.50.212 any
access-list acl_outbound permit tcp host 192.168.50.213 any
access-list acl_outbound permit tcp host 192.168.50.214 any
access-list acl_outbound permit tcp host 192.168.50.215 any
access-list acl_outbound permit tcp host 192.168.50.216 any
access-list acl_outbound permit tcp host 192.168.50.217 any
access-list acl_outbound permit tcp host 192.168.50.218 any
access-list acl_outbound permit tcp host 192.168.50.219 any
access-list acl_outbound permit tcp host 192.168.50.220 any
access-list acl_outbound permit tcp host 192.168.50.221 any
access-list acl_outbound permit tcp host 192.168.50.222 any
access-list acl_outbound permit tcp host 192.168.50.223 any
access-list acl_outbound permit tcp host 192.168.50.224 any
access-list acl_outbound permit tcp 192.168.50.0 255.255.255.0 any eq smtp
access-list acl_outbound permit tcp 192.168.50.0 255.255.255.0 any eq pop3
access-list acl_outbound permit ip 192.168.50.0 255.255.255.0 host 192.168.51.0
access-list acl_outbound permit ip 192.168.50.0 255.255.255.0 host 192.168.52.0
access-list acl_outbound permit ip 192.168.50.0 255.255.255.0 host 192.168.53.0
access-list acl_outbound permit ip host 192.168.50.51 any
access-list acl_outbound permit tcp host 192.168.50.11 any
access-list acl_outbound permit ip host 192.168.50.13 any
access-list acl_outbound permit tcp host 192.168.50.225 any
access-list acl_inbound permit tcp any host MainOffice eq 3389
access-list acl_inbound permit icmp any any echo-reply
access-list acl_inbound permit icmp any any time-exceeded
access-list acl_inbound permit icmp any any unreachable
access-list acl_inbound permit ip host MainOffice any
access-list acl_inbound permit tcp any any eq ssh
access-list 101 permit ip 192.168.50.0 255.255.255.0 192.168.52.0 255.255.255.0
access-list 102 permit ip 192.168.50.0 255.255.255.0 192.168.51.0 255.255.255.0
access-list 100 permit ip 192.168.50.0 255.255.255.0 192.168.51.0 255.255.255.0
access-list 100 permit ip 192.168.50.0 255.255.255.0 192.168.52.0 255.255.255.0
access-list 100 permit ip 192.168.50.0 255.255.255.0 192.168.53.0 255.255.255.0
access-list 103 permit ip 192.168.50.0 255.255.255.0 192.168.53.0 255.255.255.0
pager lines 24
logging on
logging timestamp
logging console debugging
logging buffered warnings
logging trap warnings
logging history warnings
logging host inside 192.168.50.201
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto shutdown
icmp permit host MainOffice outside
icmp permit host ConstOffice outside
icmp permit any unreachable outside
icmp permit any echo-reply outside
icmp permit any inside
mtu outside 1500
mtu inside 1500
mtu intf2 1500
ip address outside pppoe setroute
ip address inside 192.168.50.1 255.255.255.0
ip address intf2 127.0.0.1 255.255.255.255
ip audit info action alarm
ip audit attack action alarm
no pdm history enable
arp timeout 14400
global (outside) 2 interface
nat (inside) 0 access-list 100
nat (inside) 2 192.168.50.0 255.255.255.0 0 0
static (inside,outside) tcp MainOffice telnet 192.168.50.201 telnet netmask 255.
255.255.255 0 0
access-group acl_inbound in interface outside
access-group acl_outbound in interface inside
timeout xlate 8:00:00
timeout conn 7:00:00 half-closed 6:00:00 udp 7:00:00 rpc 7:00:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 7:30:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.50.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set myset esp-des esp-sha-hmac
crypto map vpn1 10 ipsec-isakmp
crypto map vpn1 10 match address 102
crypto map vpn1 10 set pfs group2
crypto map vpn1 10 set peer ConstOffice
crypto map vpn1 10 set transform-set myset
crypto map vpn1 20 ipsec-isakmp
crypto map vpn1 20 match address 101
crypto map vpn1 20 set pfs group2
crypto map vpn1 20 set peer BftOffice
crypto map vpn1 20 set transform-set myset
crypto map vpn1 interface outside
isakmp enable outside
isakmp key ******** address ConstOffice netmask 255.255.255.255
isakmp key ******** address BftOffice netmask 255.255.255.255
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash sha
isakmp policy 10 group 1
isakmp policy 10 lifetime 86400
telnet ConstOffice 255.255.255.255 outside
telnet 192.168.51.0 255.255.255.0 outside
telnet 192.168.52.0 255.255.255.0 outside
telnet BftOffice 255.255.255.255 outside
telnet 192.168.50.0 255.255.255.0 inside
telnet timeout 10
ssh 0.0.0.0 0.0.0.0 outside
ssh 192.168.50.0 255.255.255.0 inside
ssh timeout 20
vpdn group pppoex request dialout pppoe
vpdn group pppoex localname xxxxxxxxx
vpdn group pppoex ppp authentication pap
vpdn username xxxxxxxxxx password *********
terminal width 80
: end
well i'll be a son-of-b!*$@!!!! i have no idea what i am talking about then!!! HA HA.
i am just glad you are working, and maybe someone else watching the boards can help us understand.
Later.
36 Replies 36
wolfrikk
Level 3
Level 3
Two things I would look at first. Do a Show Xlate and see if the static mapping shows up, and make sure that the server does not have a dynamicly NATed IP. If you do not see the Static Mapping, do a clear xlate, then another show xlate and see if the static mapping connects. Second, you can do a show access-list acl_inbound and see if there are any hits on the ACL.
Ok, first, I forgot to add the following lines, but it still didnt fix the problem, but these are now added:
access-list acl_inbound permit tcp any host MainOffice eq pop3 (hitcnt=0)
access-list acl_inbound permit tcp any host MainOffice eq smtp (hitcnt=0)
access-list acl_inbound permit tcp any host MainOffice eq telnet (hitcnt=0)
Second, when I run xlate, Ive got a bunch of entries, but the only ones that seem to pertain to the issue are:
PAT Global MainOffice(63878) Local 192.168.50.13(2461)
PAT Global MainOffice(25) Local 192.168.50.13(25)
I did a clear xlate, and then a show a few seconds later, and still have not seen the 10.13 show back up in there.
No NAT'ing is happening anywhere but on the PIX, so the only NAT's I have set there are statics.
the hit list shows as follows:
access-list acl_inbound permit tcp any host MainOffice eq smtp (hitcnt=2)
I've tried hitting all 3 ports, the smtp and pop3 via telnetting to their ports, no connection from the outside IP, but can connect from the servers inside IP.
and I've tried telnetting to the .201 entry from the outside IP, and no go there as well. Again, from inside these services work fine.
Thanks for the quick response, maybe this will help you with narrowing down the issue.
It looks like you do have a dynamic PAT pool set up. The following commands will allow the entire 192.168.50.0 network NAT outside using the Outside interface's IP Address.
There are two hits on the ACL for smtp, so it looks like the static map is connecting. The next step would be to start a debug and see what the packets do when the PIX processes them from the outside. You can try a "debug access-list all" and try connecting from the outside and see what the access-list is doing.
I tried the debug access-list all, nothing seemed to pop up when i tried to use those statics by telnetting to port 25 and 23 for the outside IP. I then did a show access-li acl_inbound and the smtp traffic hitcnt has moved to 5, but that didnt change in succession with the telnet attempts. It seems to be going up possibly in relation to the active email server on IP 50.13.. maybe?
I havent seen anything show from the debug though.
I see what you mean about the dynamic PAT, my bad. Although I dont see how that global and nat statement should prevent the static PAT from happening. One of my statics has worked for a while for port 3389.
Thanks again for your time,
Dave
I wasn't implying that the Static mappings were the problem. In the past, I have seen issues where the newly created static mapping would not work and when looking at the show xlate, the server already had a dynamic NAT Mapping. That dynamic mapping would have to time out before the static mapping would connect. Clearing the xlate would force the PIX to remap everything. One thing that may make everything easier to see would be to create the static mapping useing IP Addresses only, and not using the Hostnames. This was we will know the two IP's are mapping correctly.
On the debug, are you connected with a console cable or telnet? If you are using telnet you will have to enter the "terminal monitor" command to see the debug information. By default, all system information is only displayed on the Console.
Oh, my bad again, learned something :)
the static mappings were actually created with static IP's, but the config has taken my names and automatically put them in, I have kept the names in there since its easier to replace 3 IP's with x.x.x.x for display here instead of every entry in the config :)
Well, I'm still not seeing those static PAT's in xlate, just dynamic ones. Its strange though since below you can see it building the PAT when I attempt to connect.
Ok, from the console I see: (just a little of it, im sure you dont want to see all the masses of dynamics, but i included one, the rest are built outbounds)
168.50.201/2413 duration 0:02:01 bytes 0 SYN Timeout
305011: Built dynamic TCP translation from inside:192.168.50.10/3846 to outside:
x.x.71.7/64579
302013: Built outbound TCP connection 129518 for outside:x.x.71.7/23 (x.x.71.7/23) to inside:192.168.50.10/3846 (x.x.71.7/64579)
302013: Built outbound TCP connection 129530 for outside:x.x.71.7/25 (x.x.71.7/25) to inside:192.168.50.10/3851 (x.x.71.7/64585)
302013: Built inbound TCP connection 129531 for outside:192.168.51.51/1226 (192.168.51.51/1226) to inside:192.168.50.10/445 (192.168.50.10/445)
302015: Built inbound UDP connection 129532 for outside:192.168.51.51/1228 (192.168.51.51/1228) to inside:192.168.50.10/389 (192.168.50.10/389)
302013: Built outbound TCP connection 129533 for outside:x.x.6.213/110 (x.x.6.213/110) to inside:192.168.50.204/1210 (x.x.71.7/64586)
Thanks for your patience on this.
Dave
Dave,
I had a similar problem the best info I got was from the following link
javascript:newWin('http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_v52/config/examples.htm#xtocid7')
If the link does'nt work then my problem was on the site as "cross interface on PIX 515 Fails"
Hope this helps
Ian
idodd
Hope this helps
Ian
thanks for the link, but I think I've covered everything they list there... didnt hurt to read though :)
I also tried just now to unbind all access-lists, thus basically opening up both inside and outside interfaces. Then I tried to connect, and still had no dice. So that would imply that the access-lists arent the culprit.
My static statements seem to be text-book, yet in xlate I see no PAT entries pointing to the 3 statements in question.
(those being:
255.255.255 0 0
My smtp access-li has moved to 7 on hitcnt, but thats only since I added it this morning about 5 hours ago with multiple attempts to access it since then.
So... I'm still stumped, thanks for your help guys.
Dave
PIX's by default do not allow any traffic from outside until you let it in. If there is no inbound access-list on the outbound interface, all incoming traffic should be blocked. What I normally do when I have very weird problems with access-list is to try a very liberal access-list. Create an access-list allowing all IP traffic from the external IP Address you are using to test to the outside IP Address you are using for your static mapping to the email server.
access-list test permit ip host host
We should be able to test the static map and IP connections with this access-list.
I have run into situations where with the way that a particular mail server is being accessed and/or with what parts of the smtp flags are needed, it may not work with fixup protocol smtp 25. So what I would suggest for a test is to turn off fixup for smtp. Remember fixup only allows certain smtp flags thru...turning it off allows all.
TRY:
no fixup protocol smtp 25
Just to see if it works. Hope this helps.
That is a good point. PIX's only support SMTP. If the email server is configured for just ESMTP, you will have to disable the fixup protocol for smtp for ESMTP to work through the PIX.
dang, i knew better on that one, ha, im scoring lots of idiot points today :)
It's the outbound access list that lets all go out if theres nothing there not the inbound.... oops
So I just slapped the line
access-list test permit ip host x.x.71.7 any
and assigned it to my outside interface. (not sure what to put to fit your "Global IP of Static Map" since I have several computers assigned to diff ports for our 1 external IP that we have)
I didnt get anything different from that, and the hitcnt's didnt go up any.
If you had something diff in mind for that line, let me know, I apologize if I didnt catch what you meant by Global IP of Static Map.
In response to the other two posts...
For sake of argument I tried to do a no fixup smtp 25, which really didnt change anything, but we knew it was a deeper problem since I also cant get my telnet traffic to go through on a static either, and thats nothing but standard telnet traffic, nothing special.
But I dont mind any and all suggestions either way.
Thanks...
The Global IP of Static Map is the x.x.71.7 IP Address. The External address is the IP address you are using to test from outside you network. You could try this Access-list temporarly, but it will allow all IP traffic to the x.x.71.7 Server.
access-list test permit ip any host x.x.71.7
If this works, change to this one to test just the protocols.
access-list test permit tcp any host x.x.71.7 eq 25
access-list test permit tcp any host x.x.71.7 eq 23
This ACL will test just STMP and Telnet. Then we can go from there.
