08-24-2005 08:46 AM - edited 03-09-2019 12:14 PM
I have a very strange issue with my home boxes. I've a brand new Cisco871 router with advance ip services and linux box behind of this router.
I use private subnets on the LAN and router makes NAT for in/out traffic. Incoming traffic NATed by static NAT entries.
Everything works fine except my apache web server. When a client uses http 1.0 protocol everything is fine, but when someone tries with http/1.1 the trasfer timed out. When I check the router and http inspect logs I can see the packets are sent back in this case too, but never arrived to the destination.
have you seen something similar to this?
the same configuration was ok with a linksys broadban router and a linux netfilter based firewall.
Thank you
Laszlo
08-26-2005 03:01 AM
You know the packets are sent - is that to the 871? Do you know if they leave the 871 - do you have a way of grabbing the packets after they leave the 871?
Can you do a packet capture on the client pc that is somewhere else?
08-30-2005 02:55 AM
It is looks like the problem was some wrong MTU setting on my linux box... it is strange, but now my site is working again
