01-28-2008 06:44 AM - edited 03-09-2019 07:58 PM
Hi all
I have some problem to establish a TS session between 2 desktops. I have 2 C831 with IPSec VPN between them and everything work fine. But if I take 2 C871 with the same settings, the session is not establish properly.
Here's my interface settings:
831
LAN (e0) : ip tcp adjust-mss 1380
VPN (tu0) : ip mtu 1436
871
LAN (vl1) : ip tcp adjust-mss 1380
The only difference is the LAN interface. I tought that maybe a VLAN header increase the packet size but it's not.
The only workarounds that I found is :
Set the ip tcp adjust-mss to 1330
OR
Disable the hardware encryption,
Does anyone has already have that kind of issue ?
Thank you very much
01-28-2008 09:09 AM
Have you tried pinging different packet size with the IPSEC Tunnel up between the 831's.
Unless its a software or hardware caveat, I would not disable hardware encryption. Depending upon what you have configured on the 831, the 831 CPU may be overwhelmed with encrypting/decrypting packets. So, I would give the "ip tcp adjust-mss" command a shot.
Arul
** Please rate all helpful posts **
01-28-2008 12:00 PM
I try this on 831 and on 871, but I reach the same packet size
ping [IP address of the remote node] -f -l [packet size]
At 1346 I can ping, but at 1347 (packet must be fragmented) on both devices.
What's the difference between those routers ?
