ā03-03-2011 12:06 AM - edited ā03-09-2019 11:25 PM
I have a query on TCP/IP communication. Let's say I have a cisco device running with http server disabled. If I send a TCP syn packet to the device with destination port 80/443(any non-listening port), will the device respond with TCP RESET? Or will it simply drop the packet without any acknowledgement?
Solved! Go to Solution.
ā03-03-2011 07:14 PM
I think this will be different from device to device:
ASA will drop denied connection to services it does not run, to make it send resets use the command "service resetoutside" to send reset to a denied TCP packet to outside interface.
Access Points will by default reset
Routers will by default reset
Switches will by default reset
PS. Please rate and mark as right
