The difference between 3DES and 3DES-CBC
d_unafraid
Hi All
Need some guide or explaination on the different between these two.
We are configuring a site to site VPN Between a cisco ASA and a watchguard firewall. The issue is the Watchguard firewall using only 3DES-CBC or DES-CBC, Does the cisco ASA or pix support this? and are they any different from the 3DES?
I really need explain to the customer who is totally as lose as i am
Thank you folks!
m.sir
Level 7
Level 7
Hi DES has two modes ECB mode (Electronic CodeBook)and CBC mode (Cipher Block Chaining)
- Cisco IPSEC uses DES CBC mode - so if you configure 3DES or DES on Cisco you configured 3DES-CBC or DES-CBC - so it should works with watchguard. In other words there is no difference between DES-CBC and DES in this issue
M.
Hope that helps, rate if it does
