04-14-2004 11:41 AM - edited 03-09-2019 07:04 AM
I have a one hour differnce between events in SM and the time on the sensor. When I goto IDS Device Manager and setup time for the sensor I have EST UTC -300 (minutes) for east coast. I also DST of EDT with 60 (minutes) offset. Any suggestions? They don't make it easy!
04-20-2004 11:08 AM
Any update on this ?
04-20-2004 01:17 PM
I'm still waiting!
04-20-2004 04:35 PM
Which one do you believe? If you think the sensor time is incorrect you should try rebooting the sensor especially if you did not do so after modifing either offset. The sensor requires a reboot if the local time or summertime offset is changed (BTW, there has been a ddts bug written against this). This will time sync all sensor apps running on the sensor.
